Nozzy
6 years agoFriendly Neighbour
Telus Wifi Hub manual DNS not working
Hello, I have the new Telus Wifi Hub gateway and I am trying to set it up so that it configures connected clients to use a local DNS server that I have in my LAN. I go to Network > LAN and change the...
- 6 years ago
I suggest you call Telus technical support and report it so they can log it as a bug. I did that more than a month ago so they would add it to the backlog of features/bugs they are working on. I had hopes that they would quickly fix it in a firmware update for the Telus Wifi Hub but boy was I optimistic....
snakedog116
6 years agoNeighbour
I'm having the same issue. I spoke with two different people from tech support from Telus and they both had no idea what a DNS server was and even after I explained it they said they weren't sure how to fix it. (They sent me to Port Forwarding page, and then DHCP reservations, parental controls etc.)
Interestingly, changing the WAN DNS server worked... but not to my pihole, only to cloudflair (since my pihole is on the LAN, not the WAN... obviously).
The LAN DNS server, however does nothing at all.
Nozzy
Thanks Snakedog, I called Telus tech support to report this bug in the hopes that they fix it in a new firmware but it has been I don't know how many months and they still have not done anything about it... To tell you the truth, I just use my own non-Telus router now and DNS works as intended there.
