caelestia's avatar
caelestia
4 years ago
Solved
Door sensor not monitored
One of my door sensors shows as not monitored. Per the knowledgebase, I can enable monitoring via the web portal but my web portal is different from the KB and doesn't have the option to enable/disab...
  • A-B's avatar
    4 years ago
    Hmm, that's definitely odd that it's not letting you do that. In this case, your best bet would be to reach out to our SmartHome Security team directly. Send us a private message and we can get you connected!
