seanbargen
5 years agoNeighbour
Telus Wifi Hub replacing T3200
Just received a Telus WIFI Hub in the mail. Current setup is T3200 and 4 Boost units. The T3200 lives on the main floor, connected to the ONT in the garage via an ethernet cable coming from the ...
- 5 years ago
Only one port on the ONT is active so you'll need to ensure you're using port 1 on the ONT and connecting it to the WAN port on the Wifi Hub. That would be the same way the T3200 was connected.
As for coax, if the T3200 had the coax directly connected to it, mirror that on the wifi hub. The wifi hub should have a coax port on it. The one that won't have the coax is the Wifi6 box. If you have that one, it won't replace the T3200M. It'll act as an access point instead like the Boosts.
5 years agoOnly one port on the ONT is active so you'll need to ensure you're using port 1 on the ONT and connecting it to the WAN port on the Wifi Hub. That would be the same way the T3200 was connected.
