andsoitgoes
6 years agoOrganizer
TELUS boost Wi-Fi - main connected via Ethernet works, second shows “wireless” while hardwired
Hi everyone, So I have a... setup. When I got TELUS having the modem in our bedroom made sense. We had our main computer there and so that’s where the modem is. Now in our post PC world the m...
- 6 years ago
It should work (see this discussion), but I suggest you make sure the Ethernet connection is still live by connecting another Ethernet device to it, and I also suggest you ensure both the originating Boost device, and the secondary one are connected to the same switch to test.
Bigboy98
6 years agoFriendly Neighbour
I talked to the agents and some said that only one can be wired by ethernet and the others must just be plugged in. Others said that if you can manage to plug all of them in via ethernet - it's great. The first reason doesn't make sense to me, so i conclude that you can hardwire multiple Boosts in.
