RichmondBC
5 years agoNeighbour
Solutions to getting the best speed possible
Hey guys, So I have OF 1 GB internet using a T3200. my house is a singular floor and is a very deep design. The wifi signal is great throughout the house, but unfortunately, too many devices are ...
FuzzyLogic
5 years agoYou may wish to look at powerline networking. This will give you ethernet over your home power lines. I have this in most rooms in our house and can give you better speeds than wifi.
DarthVaderGinsberg
What powerline networking product do you use?
I bought an entry level 1 gigabit system at Best Buy for $79. it gave me at most 10MBPS, vs 30 to 35 via wifi, so I returned it.
- FuzzyLogic5 years ago
I have a pretty old setup which is a mix of Homeplug AV200 devices. I started with WD Livewire and have since added a couple of Netgear devices and a D-Link. They all work together well but the best speeds I see are close to 200Mbps. This works fine for my needs. The new devices are up to 10X faster.
This is my go to site for recommendations:
Best Powerline Networking Adapter 2020 | Reviews by Wirecutter (nytimes.com)
Related Content
- 13KViews1Comment
Inquiring About Possible Solution for TELUS PureFibre Installation Issues
I recently experienced a cancellation of my TELUS PureFibre installation due to the absence of a fibre connection from the outdoor telecommunication service box to my home's hub room. Currently, I on...Solved11KViews10Comments
