RichmondBC
5 years agoNeighbour
Solutions to getting the best speed possible
Hey guys, So I have OF 1 GB internet using a T3200. my house is a singular floor and is a very deep design. The wifi signal is great throughout the house, but unfortunately, too many devices are ...
RonAKA
5 years agoRockstar
Are you using both a 5G and 2.4G frequency SSID? Perhaps you could move the lower demand items like the cell phones to the 2.4G? Is there any possibility of interference from neighbours using the same channels. I have used a simple exe called WifiInfoView to view what wireless channels are being used and how heavily. The Summary view under options give the simplest view of the traffic. The idea is to pick less used channels. Not sure if this works on your 1GB internet. I only have Internet 75, but use the T3200m modem. It has these settings in it under the Wireless Advanced tab.
Related Content
- 14KViews1Comment
Inquiring About Possible Solution for TELUS PureFibre Installation Issues
I recently experienced a cancellation of my TELUS PureFibre installation due to the absence of a fibre connection from the outdoor telecommunication service box to my home's hub room. Currently, I on...Solved11KViews10Comments
