Dan_emde
6 years agoNeighbour
Setting up Chromecast on both guest wifi and main wifi
I have a T3200M and am trying to get a Chromecast connected to both my guest network and my main network. When setting up the Chromecast I would get to connecting to wifi and sometimes it works but m...
- 6 years ago
You might be best to create a separate subnet using an additional router for the suite. That way all traffic is separated from your network. If you are on Fibre, you could place a switch between the ONT and two routers; or you can bridge Port 1 of your main router to use for the second network.
6 years agoso 2 Chromecast devices, each connected to a different SSID, and managed independently by the viewer of the TV?
Dan_emde
That would be correct.
- NFtoBC6 years ago
- Dan_emde6 years agoNeighbour
Thanks! I'll give that a try. I will have to wait until our current guest leaves before trying it as I kind have it working, not how I want to right now, but it works.
Thanks,
