3 Messages
Closed
OptikTV conflicts with WiFi Extender. Help!
Hi. I’m using Telus for my internet, TV and home phone now. My internet service is “TELUS Internet 150” and my Optik TV service is “Essentials”. The technicians came to my home last Thursday (Mar. 2nd, 2023) and installed the latest equipment for the above services. I have 3 Telus equipment now: a white square router on the wall, a white cylindrical booster and a black box for the TV. I’m also using my own “Netgear AX1800 WiFi Mesh Extender (EAX20)” because the internet signal in some rooms is not good. My own wifi extender’s power’s plugged in a different room and it’s connected wirelessly to the Telus machine. The wifi extender conflicts with the TV signal. When the wifi extender’s plugged in, the TV shows “Television signal has been lost” error page (but internet and phone are all good). If I unplug the wifi extender, the TV’s working again. I’ve tried unplugging the machines, I’ve tried all the options in my wifi extender, and nothing works. I can’t log in to the Telus router as “admin” even though I have the password; it keeps telling me that I typed “Invalid Username or Password”. Any solutions for the TV and wifi extender confliction? Thank you.
If the products of “Netgear” don’t work with Telus, what wifi extenders work best with Telus? Does Telus provide their own wifi extenders? Thank you.
Discussion
Updated
5.7K
2
0
0
Top Contributors
View MoreTELUS_Support
+22 more
Community Manager
8.1K Messages
FuzzyLogic
+25 more
1.8K Messages
Coach
30 Messages
Community Stats
Total Posts
Total Members
+33 more
TELUS Team Member
Sounds like your TV is trying to connect to your mesh network, which usually causes problems. Can you connect it by Ethernet?
Telus routers usually are found at IP address 192.169.1.254, with the password found on the device itself. Depending on which ‘square box’ you have, it may or may not be the router. The password may be hidden under a lid. Can you provide a more detailed description? If the cylinder is indeed a booster, it will be assigned an IP address by the router, and you will need that address to access the admin panel.
Finally, Telus does indeed have its own mesh product: Wi-Fi plus.
3
0
rc
+11 more
Rockstar
Based on the statement that the Set top box is connected to the TELUS modem via an ethernet cable and TV works when the netgear equipment is turned off, I suspect a configuration issue with the net gear equipment
0
