shegide
3 years agoOrganizer
No video, no sound on Toshiba Smart TV
I've had the TV for six years and it's been perfect. No problems whatsoever, no signs that it was failing. So, a few days ago I was watching a movie on Netflix and about half-way through I hit back/e...
- 3 years ago
Sounds like a back lighting or main board issue. The very least you should be able to see the TV menu regardless of a source connected to it. I believe it's time to shop for a new TV.
3 years agoHero
The remote may work and show menu items but that doesn't mean the HDMI port is working on the TV. The test with a DVD player on the TV HDMI port will show if the problem is the TV port/HDMI cable or the Optik box.
- shegide3 years agoOrganizer
Hey xray. Well, that didn't work and I think I might have fried my DVD player, which is old (2007) anyway so no great loss. After I made the switch it made a lot of noise, then it settled on a H02 error. I'm going to call Telus and try to make an appt for a tech to come. If it's the TV I want to be positive it's the TV. Then I can move on and get another one.
So, thank you for your help. It made a lot of sense and it helped narrow it down.
