shegide
3 years agoOrganizer
No video, no sound on Toshiba Smart TV
I've had the TV for six years and it's been perfect. No problems whatsoever, no signs that it was failing. So, a few days ago I was watching a movie on Netflix and about half-way through I hit back/e...
- 3 years ago
Sounds like a back lighting or main board issue. The very least you should be able to see the TV menu regardless of a source connected to it. I believe it's time to shop for a new TV.
shegide
Hey, thank you! But just to be clear, I remove the HDMI cable from the input socket on the back of the TV and insert it into the HDMI socket on my DVD player. The socket on my DVD player says HDMI output or is that irrelevant?
- polecat3 years agoAll-Star
shegide xray If your tv remote allows you to get to set up and settings on the screen. The tv should be ok if not tv probably no good. Am i correct Xray. Hourly cost of repair i high if you can find someone a 6 year old tv the required toshiba parts will be somewhere in the world not stocked anymore. My wife and i set up a appliance replacement account in the bank and about 5 years into the appliances age we start putting a small amount into it for appliances aging out. Bad year 2019 fridge stove w&d tv all in 14 months that cleaned it out. We now starting to put some back for down the road. It helped the wallet burn.
- shegide3 years agoOrganizer
Hey Polecat, the TV remote does not work. The only thing I get on the screen is the Toshiba logo screen for a few seconds then it goes to black again. I can turn the TV off and on with Telus remote but that's all.
- WestCoasterBC3 years agoCPU Alum
