johnlittle
4 years agoNeighbour
No internet (red light no fibre connection / error)
Hey guys, I need help. My telus wifi hub router is not working as the Wifi signal is blue but the internet is red with the detailed sign as (no fibre connection/error) I don’t know how to help fix thi...
loyalClient
4 years agoCoach
What do you mean wifi signal is blue but the internet is red?
You can try to factory reset it then reboot it.
4 years agoA red internet light means it has no connection to Telus. As long as the cables are all still properly connected, that typically involves tech support and/or a repair tech.
