Nolan603
6 years agoFriendly Neighbour
Looking for help for setting up a gt784wn modem
I bought this modem and thought it would work as my Telus modem/router and I doesn’t work but is way I can this router
6 years agoThe GT784WN is seriously inferior when compared to the Telus provided modem/gateway.
- The GT784WN is only an ADSL2+ modem (max speed 24mbps). Telus uses VDSL2+ now for copper based connections which is far, far faster. It's one reason why it won't work as a modem.
- The GT784WN only has 100mbit ethernet ports on it. That's a downgrade from the gigabit ethernet ports on Telus' T3200M.
- The GT784WN only has 802.11 b/g/n wireless support. That's a downgrade from the 802.11 b/g/n/ac on Telus' T3200M.
- The GT784WN does not have a LAN port so it can NOT be used as a router.
You're better off either using Telus T3200M instead. I use the T3200M when gaming online and I haven't noticed any issues.
Finding third party modems that will actually work with Telus' specific VDSL2+ implementation is extremely difficult. If you're on fibre optic, that will open up other options.
Nolan603
Can I use my Netgear router as a VPN on the t3200m some how to mask my ip
- Nighthawk6 years ago
There are several ways to mask an IP but none of them I've tried will result in better game performance.
- Nolan6036 years agoFriendly NeighbourOk how can I do that I won’t worry about the connection I just wanna keep on playing instead of losing my internet for several hours from other people online
Why would you lose your internet for several hours from other people online?
Is your home internet or wifi connection unstable, or are getting kicked/banned from game servers?
