Nolan603's profile
Friendly Neighbour
6 Messages
Closed
Looking for help for setting up a gt784wn modem
I bought this modem and thought it would work as my Telus modem/router and I doesn’t work but is way I can this router
Advocate
3.2K Messages
Do you currently have Telus services? Telus always supplies a modem/router with your service.
Friendly Neighbour
6 Messages
Yes but I bought to see if would be better for gaming and I totally bought the wrong one I guess
6.8K Messages
The GT784WN is seriously inferior when compared to the Telus provided modem/gateway.
  • The GT784WN is only an ADSL2+ modem (max speed 24mbps). Telus uses VDSL2+ now for copper based connections which is far, far faster. It's one reason why it won't work as a modem.
  • The GT784WN only has 100mbit ethernet ports on it. That's a downgrade from the gigabit ethernet ports on Telus' T3200M.
  • The GT784WN only has 802.11 b/g/n wireless support. That's a downgrade from the 802.11 b/g/n/ac on Telus' T3200M.
  • The GT784WN does not have a LAN port so it can NOT be used as a router.
You're better off either using Telus T3200M instead. I use the T3200M when gaming online and I haven't noticed any issues.
Finding third party modems that will actually work with Telus' specific VDSL2+ implementation is extremely difficult. If you're on fibre optic, that will open up other options.
Top Contributors
View More
Community Stats
Loading...
Total Posts
Loading...
Total Members
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
