Santos
3 years agoNeighbour
is telus speed test the same as google speed test?
Hello Telus Forums. Why do i get 1ms 940mbps download speed and 940mbps upload on telus speed but only get 50-150mbps download and 50-400mbps upload on google speed test like does the plan only work...
Foonus
3 years agoAmbassador
The telus speed test by default connects to the closest telus server on the telus network before they have to deal with external internet routing. The goal of this page is mainly for installers and tech support to be able to point you at a page that shows your connection is fast and get you off the phone with your speed complaints. Bandwidth throttling and long routing delays don't affect your speeds as drastically to that site. I have my suspicions that the traffic to the telus speed test sites is also prioritized, but it remains a suspicion.
Next time you try the telus speed test use the pull down menu to manually select the furthest server away from you (they show the distance) it will requires more hops routing there and you should see similar numbers to your real world performance.
Mathiau
3 years agoFriendly Neighbour
You are right, companies do prioritise traffic to speed tests sites, all the top known ones, to show people they are fast.
And because of the contracts we are forced to sign for any service, their speeds are always only "upto" and only "to" the main connection into the ISPs network. This lets them massively over subscribe their services and use contracts to go "meh, sorry, too bad so sad"
- Randolph3 years agoFriendly Neighbour
Do you have any citations for your assertions?
- Mathiau3 years agoFriendly Neighbour
I do not have access to Telus's network to confirm configurations, but many years of dealing with ISP's from a personal level to a business level and locating problems on their side for them to fix, myself, and many other technical guru's have shown over the years that speed tests sites like Speedtest.net have priority traffic with in ISP's networks, and it makes sense, as those speed test sites are hosted with in the ISP, so you are remaining with in their networks.
It is always good to choose several sites with in an area from different providers to get a more general idea about speeds, and then if possible, find some of the lesser known speed test sites to do file downloads from to see your speeds and compare.
