brians's profile
Organizer
18 Messages
Closed
How to remove/reset WPS WiFi from Optik TV 4K Box
I cannot figure out how to do this - to make it forget the network.
I have a DVR and three Optik TV 4K boxes. One has never been connected to WiFi which is OK because it is ethernet. Another is on WiFi because I have no network port near it. A third I have a network port but it was previously connected to WiFi and I have an issue with this as follows...
A bad situation can occur when a power failure happens and the order of my network equipment starting up...
- The Optik 4K box does that not detect the LAN port is active upon power up, because the switch it was connected to was not fully booted up yet.
- Therefore the Optik 4K box connects to WiFi
- Switch finally boots up and since the Optik TV 4K Box is connected to LAN, it creates a switch loop causing a broadcast storm and takes out the entire LAN and all the Optit TV.
When you connect an OptikTV 4K box to WiFi, the LAN port on it creates a bridge - eg. you can connect a computer or something else to it and it will be connected to your LAN.
I spent 2 hours a couple weekends ago troubleshooting this.
Community Manager
8.1K Messages
Hey brians - Why not boot up the Ethernet switch first, or leave it on so the box never loses LAN connection?
- Eric
Organizer
18 Messages
A place in Beverly Hills helped me resolve this issue đŸ™ƒ
3 Messages
What was the solution?
Top Contributors
View More
Community Stats
Loading...
Total Posts
Loading...
Total Members
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
