Janzep
2 years agoFriendly Neighbour
Ethernet connection
Do I need to change a setting for my Telus box to accommodate Ethernet or just hook up the cable
- 1 year ago
Here is the manual for that device as well as information on the various indicators. If the Link indicator is green you are using wired. If not then it's either not connected or using wireless:
Janzep
1 year agoFriendly Neighbour
Arris VIP5602wt
Sent from my iPhone
Sent from my iPhone
FuzzyLogic
1 year agoHere is the manual for that device as well as information on the various indicators. If the Link indicator is green you are using wired. If not then it's either not connected or using wireless:
- Janzep1 year agoFriendly Neighbour
TYSM. This is a huge help and a relief to know that the data is traveling by wire.
