Janzep
2 years agoFriendly Neighbour
Ethernet connection
Do I need to change a setting for my Telus box to accommodate Ethernet or just hook up the cable
- 1 year ago
Here is the manual for that device as well as information on the various indicators. If the Link indicator is green you are using wired. If not then it's either not connected or using wireless:
Rocky3
2 years agoGuardian
If it is the 21T just plug it in
