Ramzy
+2 more
Organizer
13 Messages
Closed
Samsung Galaxy S7 battery drain after April update
Hey there,
Telus recently (April 18) released the April update for the S7 and the Edge. I own the S7 and installed it right away. Ever since the update, background battery drain increased significantly for me. The processes/services 'Android system' and 'Android OS' now account for 25-50% of the battery usage, whereas before they were barely listed. I've been reading online, mainly on xda, and many people are reporting this issue with Canadian, US and European versions of the phone. Looks like a Samsung issue, however I still wanted to post here and a) read what telus has to say, b) warn people who have not made the update yet (ignore it for now!) and c) whether it is possible to revert to the February/factory version of the installed operating system without violating the warranty. I would go as far as exchanging my phone for another unit even though I know Telus won't do it. It's really frustrating, the battery life was amazing before.
The issue btw extends to the deep sleep of the phone. Whereas it would lose around 1% over night, the phone now loses more than 10% (around 7h sleep).
Hope to hear from other users and especially telus.
All the best
All the best
Discussion
Updated
17.1K
0
0
0
This conversation is no longer open for comments or replies and is no longer visible to community members.
Top Contributors
View MoreTELUS_Support
+22 more
TELUS Team Member
8.1K Messages
591
FuzzyLogic
+25 more
1.8K Messages
66
Coach
30 Messages
30
Community Stats
Total Posts
Total Members
Lola
+12 more
Rockstar
I have the S7 as well. I just took the bug fix update this morning, about 2 hours ago. It wasn't a major software overhaul, just a couple of bug fixes to touch and something else, and a bit of stability--fairly small and quick. My battery is fine so far. It was at 80% directly after the update, it's still there, and I've been on the internet, etc. I know 2 hours isn't long, but with battery drain, it's long enough to notice if it's happening. On my S4 occasionally apps were sucking the life out the battery, dropping it 30% in 20 minutes of no use. That drain is not happening for me right now on the S7. My Android System is using only 10% of the battery right now. You can try power saving mode, but on the S7, power saving mode stops some apps from working properly, to save power. :smileyfrustrated:
http://www.gottabemobile.com/2016/04/12/samsung-galaxy-marshmallow-problems/ -- From this article you can link off to help pages, but if you're reading XDA, then you're likely already aware of everything in it.
Fingers crossed that if enough people complain now, a bug fix to your problem will arrive sooner than later.
And you can factory reset -- just Google that, lots of help around to walk you through it if you go that route.
0
Malek777
+2 more
Organizer
0
0
