ricksa
3 years agoNeighbour
telus Flex Data Plan for Tablets
I currently have a "Telus Flex Data Plan for Tablets". Can you please provide an overview of the fees?
BrandonT
TELUS Team Member
3 years agoHi Ricksa,
The "TELUS Flex Data Plan for Tablets" appears to be a grandfathered plan. There were 2 different releases of this plan. The details below are only accurate if your Flex Data Plan was added after April 02, 2014.
Please Note: Your device must be programmed with APN = isp.telus.com; if any other APN is used (e.g. sp.telus.com) then all data is charged Pay Per Use rates.
| Data usage |
- ricksa3 years agoNeighbour
Thank you, Brandon. Indeed, ours is a grandfathered plan from Feb. 2014. Do you have the details for the earlier release of this plan? Much appreciated.
- FionaAM3 years agoNeighbour
According to my files, Brandon's table _is_ the earlier version. They raised the base price at some point and the top end of the usage. I confirmed this pricing information below with Telus directly on December 1, 2021:
Flex Data Plan (Confirmed Dec 1, 2021, best data plan available)
$7 0-10MB
+$5 10.01-100MB
+$10 100.01-500MB
+$15 500.01MB-5GB
+$0.02/MB in excess of 5GB
Hope this helps.
