shahbazpasha
20 hours agoJust Moved In
“Persistent TELUS Mobility Signal & Network Issues on 3 Lines – Looking for a Resolution”
I have been a TELUS Mobility customer with three mobile lines, and my monthly bill is approximately $400. Unfortunately, for quite some time I have been experiencing persistent weak signal and unreli...
shahbazpasha
19 hours agoJust Moved In
Thanks for sharing your experience. I completely understand that concrete buildings, high-rises, tower congestion and other environmental factors can affect cellular signals indoors.
However, my issue is not limited to my home or one particular building. I am experiencing weak and unreliable service in different locations, including regular city areas and while travelling around the city. That is why I contacted TELUS technical support.
In my most recent conversation, the technical representative acknowledged that there are currently significant network issues in some areas and that they may not be resolved quickly.
I understand that no carrier can provide perfect coverage everywhere, but when the problem is persistent across different locations, I believe it is reasonable for a customer to ask for a proper investigation and solution, especially when paying for three lines.
I appreciate your feedback and sharing your experience. Wi-Fi calling can certainly help at home, but ultimately I would like the cellular service itself to be reasonably reliable when I am away from Wi-Fi as well.
15 hours agoHey shahbazpasha - are you experiencing these issues with 5G+ or LTE?
- shahbazpasha15 hours agoJust Moved In
Hi, thanks for your response.
The main issue is the network signal itself, not specifically whether I am connected to 5G+ or LTE.
As I mentioned in my original post, I have been experiencing network issues since April. The problem affects not only mobile data/internet but also basic calling service.
For example, one day while I was in Newmarket, I had no usable signal and was unable to make even a normal phone call. I also frequently experience very weak signals in different parts of the GTA.
So my concern is broader than 5G+ or LTE performance. The basic network coverage and signal strength have been unreliable across multiple locations for several months.
I would appreciate it if TELUS could investigate the overall coverage/signal issue rather than treating this only as a mobile-data or 5G issue.
