10-10-2015 09:55 AM
I just received the newest remote. I used the Samsung code and it works to power my tv on and off. But that's the extent of it. Am I missing something or call all this new remote do is turn my tv on and off? The old one had the input & menu option.
10-10-2015 11:27 AM
The menu option is present on the Slimline 2, however it does not seem to have the input selector. On my TV the Slimline 1 remote does not cycle through the inputs, but only switches to the Video input, so I never used that option, but kept the original TV remote for that purpose.
10-10-2015 10:43 AM
SEARCH button is the Input as it states on the remote. Along with menu etc. Long as you programmed in the right Samsung code those functions will work with it.
10-10-2015 10:45 AM
Those buttons were there on the last remote... But this one is brand new. There are no secondary options printed on this new version
10-10-2015 10:49 AM
Which remote do you have? The newest released one.. Or the previous version..
http://static.telus.com/common/cms/files/get-help/TELUS_Slimline_Remote_2_Insert.pdf
10-10-2015 11:27 AM
10-10-2015 11:37 AM
it worked on the slimline1, i could scroll options and select.
