i have outlook 2007 and POP3 and IMAP dont work - will they work now ??
thetods
I have called numerous times, and had numerous "fixes" that never did anything ...
most annoying because all they wanted me to do was use an old email program ...
1 REPLY 1
BillTelusCust
Rockstar
Use the fully qualified domain name of your POP3 or IMAP server and make sure you are using the correct port.
Outbound email will have to likely be on Telus' outbound SMTP servers on your mobile phone - but different on Wi Fi.
Make sure you get a service which allows you to send outbound email on it so you don't have to mess with that.
