07-08-2017 12:26 AM
07-08-2017 12:37 AM
To clarify....
07-08-2017 12:39 AM - edited 07-08-2017 12:54 AM
A modem/router consumes very little in terms of power consumption. 2.4 or 5ghz it makes no difference. The device itself consumes very little power. If you notice a massive spike in your hydro consumption. I strongly suggest you log into your BC hydro account and view your consumption. The graph charts the last 7 days for kWh usage. Or you can view usage hourly.. Keep in mind the charts are delayed 24 hours.
Being a heatwave is going in most of the province any appliance like an A/C or Fan will be the culprit. Also if you fall into step 2 rates the prices increase as well. Your increase in demand will not have anything to do with Telus.
If you have a digital meter (which you should in BC since they changed analog ones out) you can have it tested at your expense to verify if it's accurate. But if you want to go that route you should be documenting every ounce you consume yourself and keeping a detailed log. Chances are consumption is up from something you're using in your household (not a telus device).
07-08-2017 10:08 AM
