07-15-2021 02:51 PM
MyQ is supposed to work Alarm.com that is used by Telus Security system.
The procedure is to go to www.alarm.com and add MyQ liftmaster from Automated devices.
But I don't see the option for automated devices in alarm.com, it has only automation rules.
Has anyone able to add their garage door to alarm.com?
07-19-2021 05:10 PM
I have accessed my TELUS Security account via My TELUS account, not via alarm.com
To add an automation device, once in the screen where you can manage and view your devices and add rules, etc.... you click on Settings in the left hand menu, then Manage Devices, then Add a Device, then pick Garage Door.... MyQ is in that listing. Here is the support article on the TELUS site:
Hope that helps
11-09-2021 01:48 PM
When I log into my alarm from the Telus site I get sent to the Alarm.com GUI and when I click ADD DEVICE all I see are the telus sensors, no option for GARAGE DOOR, MyQ etc
07-19-2021 05:10 PM
Hope that helps
11-09-2021 01:48 PM
