The content you are looking for has been archived. View related content below.
on 03-21-2023 01:01 PM - edited October
How To Block Text Messages and Calls on an Android Device
There's not many things more annoying than unwanted texts or calls. Here are some quick guides on how to prevent them from getting through to your Android device.
(note: This will block calls from private or unidentified numbers. You'll still receive calls from numbers that aren't stored in your contacts list)
If you've made an error or changed your mind, here is how to unblock numbers from text conversations or calls.
Always remember as well, TELUS has a handy (and free!) feature known as Call Control which will prevent nuisance calls from getting through to you. Be sure to check it out!
