PVR constantly freezing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-28-2022 03:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-28-2022 03:35 PM
Wired or wi-fi? If possible try a wired connection if not already using one.
This may help as well:
How to reboot your Optik system | TELUS Support
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2022 05:52 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2022 05:43 PM
Were you able to try out FuzzyLogic's suggestions? Failing that, and if it is happening on more than just one specific channel then it may be a hardware related issue, in which case you'd need to call it in.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2022 07:07 PM
Have you done a speed test over WiFi with a mobile device standing next to your PVR?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2022 07:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-30-2022 08:16 PM
https://www.speedtest.net/
Ideally your phone should be on the same 2.4 GHz band as the PVR to get any indication if the WiFi signal might be the problem. Chances are your router has Smart Steering turned on so it's not going to be possible to select the 2.4 GHz band on your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-31-2022 01:45 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-31-2022 02:01 PM
Should be 15 Mbps download or higher for Optik.
