Voice automation
Jordon
I get that this has been asked before, but I can't get a good sense of what I can and cannot do via voice automation.
I used to be a part of ADT by Telus, which was running via Alarm.com app. While I couldn't directly control it via my google home, I could "talk to alarm.com" to allow me to use voice commands to arm my house and control my thermostat. Now I'm with Telus security and using the "Smart Home" app.
Is there any way to integrate this system with my google home? If not is there any other means to use voice commands to control my thermostat or arm my house? I read somewhere about using Siri. Is that possible?
Thank you!
3 REPLIES 3
You can add Siri Shortcuts from the Telus Home App on your device.
Thanks for the response! Most of those shortcuts seem pretty binary. Is there a way to set my thermostat via Siri command?
I have no experience with the thermostat, so can’t offer any advice.
