02-22-2021 12:11 PM
Hello,
1. When using the app, all the sensors are listed. However one of the motion detectors shows the status as "IDLE". The other one is "ACTIVATED". What does IDLE mean? Is there no WiFi connection? The sensor is installed on the third floor and the T3200M is on the main floor
2. I'm considering upgrading the entire WiFi network with a mesh system. How to I change all the devices and sensors to use the new W-Fi network? I will be disabling the built in WiFi on the T3200M
Thanks
03-01-2021 02:26 PM
Hi there!
To answer your questions:
Hope this helps!
03-01-2021 02:26 PM
Hi there!
Hope this helps!
