Smart home security integration with roll shutters
AlexK
Hello all,
Does anyone know if I would be able to hook up alexa to the panel. If so how? I recently got some shutters installed by these guys https://securityshutter.ca/ on the exterior of my house. They are controlled through alexa. Would like to integrate them with the telus security system.
Thank you.
Jaime2
TELUS Employee
TELUS Employee
Yes, you can.  The best part is TELUS Assist will help you with step by step instructions.  https://www.telus.com/en/bc/support/article/telus-virtual-assistant-explained
1 REPLY 1
Jaime2
TELUS Employee
TELUS Employee
