06-01-2022 07:48 AM
I only want to watch 1 channel. Every time I have it on, after 4 hours, it defaults back to PIK's main menu.
06-01-2022 01:32 PM
Hi @tonten
What device are you watching Pik TV on? If you're watching on the TELUS TV Digital Box, you can manage your screen saver preferences in Settings --> Device Preferences --> Screen Saver. If you want your TV to play forever, you can select 'Never' for When to start and 'Never' for Put device to sleep.
06-01-2022 01:05 PM
On Optik, similar activity is part of the Energy Star requirement, and can be changed by request to Telus for a change to the 4 hour limit. I do not know if the same applies to PikTV.
06-01-2022 01:32 PM
Hi @tonten
06-01-2022 07:48 PM
Chromecast. I've already configured chromecast to never turn on screensaver and ambient mode and the TV to always be on. But after 4 hours, any telus channel I'm watching turns off and it defaults back to the previous telus selection menu.
06-02-2022 12:28 PM
Do you mean Chromecast with Google TV? Pik TV doesn't currently support Chromecast.
Either way, there isn't currently a way to disable this 4 hr timer. I can pass the feedback to our Android TV developers.
06-02-2022 11:44 PM
Oh. I have PIK TV installed on my chromecast. It works fine except that I can't stream any channel for more than 4 hours before it shuts off and defaults back to the previous menu in PIK
It says on telus official page I can use it chromecast.
https://www.telus.com/en/support/article/pik-tv-app-chromecast-google-tv
