Audio Description will not turn off on AppleTV
Papaageorgio
I accidentally turned Audio Desception on one of my channels, it will not turn off even though I disabled it on the channel and in settings as well. I tested on another channel and it does the same. It only is on those two channels it remains
KHR
TELUS Employee
TELUS Employee
Hi @Papaageorgio
Thanks for bringing this to our attention. The development team is aware and is working on fixing this for the next app update. Should be pretty soon - stay tuned, or you can turn on auto-updates in the tvOS app store if you haven't done so already.
1 REPLY 1
KHR
TELUS Employee
TELUS Employee
Hi @Papaageorgio
