Using MSB router AND Boost Wireless
Reply
wlahay
Connector
Can anyone tell me how exactly I can configure the Boost wireless access points when connected to a router other than the T3200m? I want to bypass the T3200m, use my router AND the wireless access points. Before anyone suggests bridging port one on the actiontec, I want to run my network without it.
I can connect my pfSense firewall successfully with Telus fibre, but I cannot get the boost devices configured.
Suggestions?
wlahay
Connector
Sorry, the title was meant to say SMB (Small-Medium Business).
You can access the webpage interface of the Boost devices by entering their assigned IP address in your web browser. You should be able to complete set-up from there. If unable to complete the steps you want, you may need to set them up using the T3200M, and then migrate them to the router of your choosing.
