Telus Boost Wifi Wall mounting / remove stand
JWong
Hi there,
Is it possible to remove the metal stand on the telus booster and  mount it to the wall?
thanks,
John
Not without severe modifications. The Boost device is designed to stand on a horizontal surface only.
3 REPLIES 3
Thanks for the quick response.   Upon closer inspection it didn't seem like there was an easy way to remove that stand.  Unfortunate as I wanted to mount it on the wall behind my flat screen so it would be hidden.  seems like there's wall mounting hole behind the plastic ssid / password panel.
You could mount it to the wall, but the base will be offset.  Behind the TV might be a poor location for signal strength as well - lots of potential electrical interference.
