T3200M will not negotiate 1GB with switch
wlahay
Organizer
I have my new T3200M connected to a dlink 24port unmanaged switch but the interface will not negotiate 1GB. All interfaces of the T3200M are negotiating at 100MB. The 24 port switch will negotiate with other devices to 1GB ok.
Any ideas?
Thanks
1 REPLY 1
Only thing I can think of would be the cable between the two. I have an 8 port gigabit switch and it works fine with my T3200M.
