Red fail light on fiber box
S3binator
Is fiber out in or near Calgary T2N? Anything else I can try over unplug and replug fiber box?
2 REPLIES 2
Troubleshooting those boxes doesn't really encompass much. Better off calling tech support.
DarkHazzard
I would suggest no to do so, but you can try to turn it for a minute or two and check if the Fail light will gone, if not, then i prefer to call the technical support so they can do their magic.
