Is my lagging audio issue a soundbar problem, TV problem, or is it an issue with using an optical ca
Reply
mikkynoah
Resident
I just purchased a new Vizio TV(D60-F3) and a soundbar(SB3632An-F6) and no matter how much I adjust the lip-sync feature on the TV, the sound and video will not line up when using an optical cable. When I use the 3.5 to RCA cable included with the sound bar it syncs just fine, but there is a noticeable quality difference.
I understand that sometimes there is a lag because a Kodi TV has to convert the audio to digital, but is there any way to resolve this? Or might another soundbar be better?
I’m actually looking at getting a different soundbar/sub/surround sound setup, but I want to make sure it will work without lag before I waste any time on it.
Is there any reason you copied someone elses post from another website, pasted it here, and tried to insert a spam link in the middle?
If you find a post useful, please give the author a "Like" or mark as an accepted solution if it solves your trouble. Smiley Happy
