Hardwire Wireless Box
buckycat
Ambassador
Is it possible to hardwire a wireless 4k box as I am running ethernet to the area where the box is located?
WestCoasterBC
Once you plug in the network cable it will switch over.
4 REPLIES 4
WestCoasterBC
Absolutely you can run it wireless or hardwired. I myself hardwired it for optimum performance.
Just plug it in and it switches to wired automatically?
WestCoasterBC
Thanks, it worked after a reboot.
