Cisco set top box and ethernet and adding a switch
BigBen121
Advocate
I have just had the new 4k PVR form tel-us installed. My other set top boxes are all the old Cisco ones . I have coaxial cable in my house but the technician who came installed converters on all of them so now there is ethernet cable going into each box.  I know something like this question has been covered by can I add a switch to provide a wired connection to a pc that is in the same room as the cisco box? ( I have a poor signal in that room)  I am thinking I would plug the Ethernet cable coming from the coaxial to ethernet converter into the switch and then plug the pc and the cisco box into the switch. Would this work
2 REPLIES 2
Should work. Just get a good quality gigabit switch.
Thanks for your answer
