Friendly Neighbour
5 Messages
Closed
Blocking unidentified devices on my wifi (using router T3200M)
Hi Everyone,
I have noticed a number of unidentified devices on my network, and would like to block them from using my network. I have identified as many as I could, and have 'paused' Wifi for unidentified devices using Telus' My-WiFi app.
Note that I have already changed wifi name and password regularly, but the repeat offenders show up.
Under Advanced Settings -> Blocking/Filtering -> Services Blocking, I have been able to block 5 devices maximum, which is probably due to the fact that for each of the 5 services (i.e. Web, FTP, Newsgroups, E-mail, IM), individual records for each service/device pairing are entered under 'Service Blocking List'. The records under this list are now maxed at 25 (5 devices, 5 services each device).
What other options do I have? Knowing a smart guy can change their IP address and try to connect again.
Thanks for your consideration with this.
Discussion
Updated
22.4K
0
0
0
This conversation is no longer open for comments or replies and is no longer visible to community members.
Top Contributors
View MoreTELUS_Support
+22 more
Community Manager
8.1K Messages
FuzzyLogic
+25 more
1.8K Messages
Coach
30 Messages
Community Stats
Total Posts
Total Members
Accepted Solution
+25 more
Advisor
The next time these devices show up on your network don't block services. You should use the Schedule Access function which blocks all Internet access. I believe it uses MAC address so it doesn't matter what the IP address is.
0
0
+25 more
Advisor
If unknown devices keep showing up after you change the password then it's someone in your home that's giving the password out. If this is the case then your problem isn't one you can address with the router.
0
0
