I am having problems activating my lap top
Teresa_Gross7
xl
CPU Alum
CPU Alum
To clarify, what error messages are you getting?
Is your problem connecting to the wifi?  What happens if you connect the laptop via Ethernet cable?
1 REPLY 1
xl
CPU Alum
CPU Alum
