NeoOiler's avatar
NeoOiler
1 year ago
TelusTV+ Not showing episodes
Hi There, just wondering if anyone else is having the same issues as I am? When i log into telustv+ on my phone or my laptop, for shows on demand it is showing the season, but no episodes, or if i click on a show I know is in my subscription, it says It isnt. I called telus yesterday and they say they know about the issue
Thanks
  • TELUS_Support's avatar
    Hey NeoOiler if you contacted our team and we are aware of the issue, that means that it's likely that others are experiencing the same issue. Thanks for your patience while the issue is resolved
    • NeoOiler's avatar
      NeoOiler
      Any news on this? Anyone else having this problem? Doesnt work on the app either.  They said it would be fixed days ago. Any information would be appreciated
      Thanks
        Hi there, did clearing the cache not help? If you are still having this issue, can you send us a private message?
