rSquared's avatar
rSquared
2 years ago
TelusTV-21T remote programming
My TelusTV-21T remote doesn’t detect my samsung frame tv UN65LS03N. It tries 3 different codes which don’t work. I’ve tried universal learning remotes, but they don’t work with the 21T. Very frustrating!
  • A-B's avatar
    A-B
    Give these a shot:
    009
    296
    318
    294
    109
    013
    349
    178
    063
    022
    • rSquared's avatar
      rSquared
      Thanks. None of them worked. My amp is programmed for the volume buttons, so i tested using the power button and it only powers on/off the TV+ box.
      I have another samsung TV (different model) and it works fine with that one.
      • A-B's avatar
        A-B
        Gotcha. Then your best bet would probably be to reach out to our Tech Support team at 1-888-811-2323 and see if they can look into a manual sync for you.
  • did you search this forum, there are a lot of codes given for this same problem already
