Kiti63
2 years agoNeighbour
Telus remote code for NTC TV?
Telus list states it’s 1268, but that doesn’t work. Help desk says oh it’s a new brand so too bad.
has anyone else had success? What is telus timeline for fixing it?
- Nighthawk
1268? Do you have the older Optik hardware and remote? Seeing as how the remote code list with 1268 on it is from 2015, that is likely a different NTC entirely than if you bought an NTC TV from the Brick recently. You will likely have to get the remote to do a code search to see if any codes will work. If the manufacturer used a non-standard board that doesn't share codes with any on the list currently, there may be no codes that work.
I've never even heard of NTC before your post so I did some digging. The currently NTC appears to have only been in existence September last year. Their website is totally useless. It has little information other than three Android TV models and three air conditioners. No individual product pages, no specs, no reviews, no company address, details, product documentation, nothing. The "company" is owned by Best Source International Inc which is a wholesaler of re-badged Chinese products. Same last name on BSI's business records and the domain registration for NTC. Searches keep showing BSI's website as being from Hong Kong.
