VancityV's avatar
VancityV
3 years ago
Telus TV+ remote
The new TV+ remote doesn’t have several features of the old one, which makes it so much more difficult / more work to navigate. Missing: PVR button, delete button, info button, stop / fast forward functions (either its a 30 sec skip or holding it down makes FF go way too fast with no screen preview?) Why is there no PVR button to jump right to my recordings… Do I have to go through the home screen - several steps every time? I’m 30 years old (not a senior or anything) and find the new system way worse and more difficult to navigate!!
  • Optik-Kate's avatar
    Optik-Kate
    Hi VancityV , if you press and hold the REC button it brings up the recording manager. When you press "ok" after selecting a recording, a screen will pop up to ask if you want to play or delete the recording, and you can delete it from there. In terms of the "Info Button" what are you looking for? If you are looking for show details, you can always search the content via Google Voice and it will bring up a quick description. Lastly, for FF, we're currently working on adding the screen preview and it will be available in the future.
    Please check out the link Fuzzylogic shared for more tips and tricks on navigation, and let me know if anything is missing and I can look to update the guide. Thanks.
