ironhand
2 years agoNeighbour
Telus TV+: Anyone else experiencing frequent sound outages?
While watching programming from Telus TV+ (versus programming streamed from Netflix, Apple TV+, etc.), we encounter frequent instances where the sound drops out for 5 seconds or so, while the video is fine.
Has anyone else encountered this? If so, were you able to resolve it?
Thanks!
- billbennettNeighbour
I've had this problem since I switched to telus fiber optic.
- TheLastEliteOrganizer
I am having the same problem where the sound cuts out randomly for a few seconds, I also noticed it with Netflix.
Was this issue fixed with the Android 12 update?
- TELUS_Support
Can you try these steps to potentially resolve the problem:
- Restart Your Telus TV+ Box: Unplug your Telus TV+ box from the power source, wait for about 30 seconds, and then plug it back in.
- Check Your Connections: Ensure all cables connecting your Telus TV+ box to your TV and any sound systems are secure and in good condition.
- Update Your Software: Make sure your Telus TV+ box has the latest software updates installed. You can check for updates in the settings menu.
- Reset Your Network Equipment: Restart your modem and router by unplugging them, waiting for 30 seconds, and plugging them back in. This can help resolve any network-related issues.
If the issue persists after trying these steps, please send us a private message and we'll see how we can further assist.
- TELUS_Support
Hi ironhand - is this issue happening when you use your TV box, or a web browser?
- TMondorFriendly Neighbour
TV box
yes, this has been going on for a very long time and Telus has not been able to fix it. I will probably have to change tv providers because it is very annoying.
