ron9
3 years agoNeighbour
Sony Bravia TV remote - TELUS controls don't work??
I just got a nice 2023 Sony Bravia XR-55A80L, and duly followed its instructions to setup my Telus box (technicolor IPV5050), that also worked fine with my previous Sony Bravia.
My new Sony remote works fine for everything, EXCEPT for "TELUS controls".
I see the TELUS options in my menu ("Options", "Favorites" etc), but when I try to select any of them, nothing happens(?!).
Any ideas anyone??
Many thanks in advance...
- miglendaNeighbour
Hello...I too have a Sony Bravia smart 55" Tv - Model X85K, and no matter how I try, I can't program my telus Optic control to work...W have an older (10yrs) Bravia in another room and it works find....Help, Please.
Thanks
Best
Michael
- A-B
Community Manager
You can try the following steps, and if it doesn't work you can give our Tech Support team a call at 1-888-811-2323 so they can assist.
1. Press and hold both the input and OK buttons on your remote for 3 seconds. The green LED should stay on.
2. Enter the code 022 using the number pad. The green LED will blink twice and then go off.
3. Test the mute or volume up/down button. If these work, you're done.
- A-B
Community Manager
Hmm, that's definitely odd, especially if you followed the instructions. Have you had the chance to speak with our Tech Support team about this?
Related Content
Trying to control My TelusTV-T21Android box with my Samsung SmartTV remote
I have recently purchased my first so-called SmartTv and have cut cable TV out of the picture except for the Telus Optik box. It's a Samsung S95C model. Beautiful TV. I am very happy with everything ...Solved6.4KViews3Comments
