AvidCdnGolfer
2 years agoNeighbour
Optik TV Recording Ends Abruptly
I recorded the US Presidential debate and it ended in the middle of closing remarks. Is there no buffer? I can't find any settings to adjust. Is this an oversight or am I missing something?
- MrSLRockstarHi AvidCdnGolfer , I do not understand the response from TELUS-Support... If you are using the TelusTV-21T set top box for cloud recordings, then there is NO WAY to add any time extension to recordings. It's one of the many shortcomings and complained about over the past 18 months or so without resolution. The only way to add time is to manually record the following program... Which is frankly ridiculous!
- TELUS_SupportOfficial Support Team It sounds like the recording may have ended at the scheduled time, and unfortunately, the system might not have included any extra buffer time. For live events like debates, sports, or award shows, which often run longer than scheduled, it's a good idea to extend the recording time manually. https://forum.telus.com/t5/Home/Optik-TV-PVR-Extend-Your-Recording-Time/ta-p/124830 - AvidCdnGolferNeighbourI don't have these options. I assume this is an older version? - TELUS_SupportOfficial Support Team You can always send us a private message and we'll try to help!
