Alberss
3 years agoFriendly Neighbour
Optic TV+ app error Required output protections are not active
I used the previous version all the time on my Samsung tablet. Since the new updated version I cannot play any TV from the Guide. I either get this error "Required output protections are not active" or it hangs. I cannot find any explanation or workaround on your sites. I updated the app today. Is there any workaround? Can I no longer use your app from this device? It works on my phone. Anyway to get the old version back?
Hi All, thank you to everyone's efforts! We implemented a performance toggle that addresses this playback error. If your device encounters this error, it will ask you to go to settings to turn on "playback performance", and after restarting the app, VOD or live should play as expected. Thanks again for everyone's help in resolving this issue.
Please note, this toggle is intended to address specific video playback issues, if video playback already works properly on your device, then there is no need to use this toggle. However, if this toggle doesn't address the specific error you're seeing, you'll be prompted again with a specific error message and error code. Please report the full message and we will continue to work on improving this feature.
- Optik-Kate
TELUS Team Member
- AlberssFriendly Neighbour
Hi,
I wasn't asked to turn on "playback performance", but I tried it. After restarting the app the live play works!
Thanks for the fix,
Sandra
- tftowner106Neighbour
I just downloaded the Android version of the app and there is no playback performance toggle in settings. Like the other posters I have a Samsung tablet but with OS v 8.1. The app worked fine until you updated it. I contacted Telus Support via Twitter dm this past December and they said a fix would be deployed but it appears that hasn't happened yet. Very disappointing that functionality was removed for older Android devices. Guess I'm stuck watching TV on my phone.
- Optik-Kate
TELUS Team Member
Hi tftowner106 we support Android OS 7 above. Google Play store distributes the new update to customers on a schedule. You should be able to see it by next week. you must be on version 2.20.258.005 to see the toggle.
I have the same issue with my Samsung tablet, OS 8.1. I just downloaded the Telus TV+ app again and there is no playback performance toggle in Settings. I contacted Telus Support via Twitter dm this past December and was told a fix was going to be deployed at some point. I'm not happy about losing playback of both live and vod on my tablet.
- Optik-Kate
TELUS Team Member
Hi Alberss Harrisclh Susanpeyton Bob_Unlikely Hockeydad16k Chester14 did anyone manage to resolve the issue? Our development team has been trying to reproduce this error, but unfortunately it seems to only be happening on specific tablets, particularly with an older OS version, and so far we've had no luck in reproducing this error with the devices we have on hand.
If you are still experiencing this issue and is willing to share a bug report, it would go a long way to improving the handling of this error. Please see instructions below:
Please provide a few details about your tablet:- brand and model
- OS version and build version (on your tablet, Settings > About device > Software version OR Android version, varies per tablet)
- TTV+ app (inside TTV+ > Settings > App information > Build version, please make sure you're on the latest build available from the Play Store)
Please also help us understand this error and when it occurs:- Does this error occur on both live and VOD, or only live?
- Please provide the name of a few live programs (and their channels) that you tried and whether they gave the error or not
- Same for VOD, provide a few names and whether they gave the error or not
Please enable Developer Options on your tablet:- on your tablet, go to Settings > About device
- tap on Build Number 7 times until you see a message stating Dev Options are enabled (you may need to enter your device PIN)
- Full explanation https://developer.
android.com/studio/debug/dev- options
Then please capture a bug report- In the TTV+ app, try to play something that gives you the error
- then immediately go to the tablet Settings > Developer Options and tap on Bug Report
- You may be prompted to choose the type of report. Choose interactive if you can.
- After 1-5 minutes you should see a message that the bug report is ready (it may appear only in the pull down notification menu)
- Tap on the "report ready" message and share it (the best option would be to upload to Google Drive and share it to anyone who has the link, and then send the link to us so we can download it)
android.com/studio/debug/bug- report
Thank you in advance!
- DococFriendly Neighbour
It happens with any content on the Telus TV+ app on my Samsung tablet. Nothing will play. Any chanel live, and any on demand content.
Samsung Galaxy Tab S3 SM-T820 OS9 One UI version 1.1
Build Number PPR1.180610.011.T820XXU3CTD5
Telus TV+ App Version 2.20.226.0
But Report: https://drive.google.com/file/d/1jDhyXSGbLb4M9dJazamG_TZnuUkn6syd/view?usp=share_link
- HarrisclhHelpful NeighbourHere is the link from Google driveColin HarrisOn Feb 14, 2023, at 7:13 AM, Colin Harris <[email protected]> wrote:<bugreport-2023-02-14-07-00-20.zip>I have no resolve to this issue… I have created a bug report and will send it to you.To answer the questions in your email…Galaxy Tab S3Model SM-T820Android version 9Build Number PPR1.180610.011.T820XXU3CTD5I am on the latest build version availableThis occurs on both live and VOD. Every channel I try on the live guide results in the same error Channel 104 (Global TV) was the one I tried this morning but every single channel has the same result. I tried both an episode from a series and a movie on VOD and both result in the same error.Colin Harris
- Optik-Kate
TELUS Team Member
Thank you Harrisclh, I've passed this information to our development team and they will review it internally. I will share any feedback as soon as I receive them. Thank you again!
- Hockeydad16kNeighbour
I have the same problem on my Samsung tablet. I live how Telus says to contact Samsung because the Telus app doesn't work.
I just want to watch a hockey game while I make dinner.
I just installed an app to check my DRM settings. Both my phone and tablet have only Level 1, yet my phone can stream channels but the tablet can't.
Interesting. I was initially wondering about this. Decided to wait to verify if Telus requested when they called back. Crickets. Thanks for checking.
- HarrisclhHelpful NeighbourRidiculous.
Hi @KHR @Dococ @Harrisclh
Here is my Update.
I created Ticket 4321055 on 2Dec. I was told I would get a call back in a couple days. Called Dec 6 and a different Telus person created another Ticket for a "Request to the back office". He promised he would call back in a couple days. Nothing. I called today Dec 15th. There is a note from Dec 8. Try same steps with clearing cache, etc. & reinstalling. If doesn't work I'm to contact Samsung.
I guess I will wait for the next upgrade & keep my fingers crossed I will be able to watch again using the app on my tablet.
All the best,
Sandra
- HarrisclhHelpful NeighbourArg. Thanks for the update
- Chester14NeighbourI get the same message. I have a Samsung Tablet and the Optik tv app worked. The new one does not.
- KHR
TELUS Team Member
I have same problem in my samsung tab s3 with android OS9. I tried rebooting tablet and reinstalling the app, didn't work. Just trying to watch directly on the app, on the tablet. Works on my samsung phone.
- Bob_UnlikelyNeighbour
I'm using the same model tablet (Samsung S3) & the same OS (OS9), with the same problem.
- AlberssFriendly NeighbourHi,
Galaxy Tab A. Model SM-T580
I did get an email to call Technical Support Friday and did. A case was created. A screenshot of the error was obtained by Telus. It was passed on to a developer. Telus said they will get back to me in a few days. I can post an update afterwards
Thanks - KHR
TELUS Team Member
Can you give some more details about your 'Samsung tablet'? What device exactly, what OS?
You cannot revert to an old version of the app - it will not work.
- SusanpeytonNeighbourI have exactly the same problem .since optik update.. I used to be able to watch tvonmy tablet.. now error message .. required output protections are not active.. Samsung tablet galaxy Tab a.. 2016
I have the same issue. Samsung tablet running android 9.0
