Grimmt
3 years agoAmbassador
Memory Leak on TelusTVplus.com App (using Edge on PC) ?
msedge.exe consumed 8GB of memory while watching a curling event (after 2.5 hours). I killed the msedge.exe browser tab running the telustvplus app process and the memory was immediately released.
I cleaned up and started a new edge browser and found the TelusTVplus app on Edge/PC consumed approx 250-350MB every 5 minutes when watching a live program. It consumed memory even when the program was paused.
Please have a developer (either Telus or 3SS) look at this.
Perhaps the memory is used oportunistically(?), and will drop off when memory pressure becomes an issue?
Edit: removed "more" to avoid confusion - the memory consumption increased when playing and pausing.
Edit 2: elaborated on potential effect mitigation
- JanVSNeighbour
I am also experiencing this issue, are they any updates available?
- MikeWNeighbour
I am seeing this too. I even got a message from the browser saying out of memory one time. Usually it just takes a long time to exit a feed (by hitting X in upper left).
- GrimmtAmbassador
Thanks for confirming what I am seeing, Mike.
- Optik-Kate
TELUS Team Member
Hi Grimmt , I don't have answers for this but I'll check with the team and let you know when I have an update, thanks for flagging!
- JanVSNeighbour
Hoping you still have eyes on this issue Kate! Thanks for looking into this.
- Optik-Kate
TELUS Team Member
Hi, I got an update from the lead on this that the memory usage is within the acceptable levels. That said, we'll do some more verifying internally to see if any optimizations can be done. I will update again when I hear back!
