1 Message
Closed
Live Guide
Until a few weeks ago, I was able to watch pik TV and change channels using the LIVE GUIDE, but now, it gives an error message stating that I do not have a subscription for the channel (even though I do), and takes me out of live TV and goes to the full screen GUIDE. It is an extra step to change channels from previously. Any reason why? I use Android box. Cannot find any link for Pik TV app Update. I have tried logging out and back in, to no effect.
Discussion
Updated
2.4K
1
0
0
Community Stats
Total Posts
Total Members
khr
+16 more
TELUS Team Member
Are you using the TELUS-supplied TELUS TV Digital Box? If so, you should still be able to bring up the live guide from playback using the up/down arrows on the direction pad (the circle around the OK button). You can check to see if there are any updates to your box at Settings --> Device settings --> Device Preferences --> About --> System update. If there are no updates available, I'd recommend a reboot.
If you are using a 3rd party Android TV device, the Pik TV app was replaced with the TELUS TV+ app in 2022 and is no longer supported. I would recommend downloading the TELUS TV+ app from the Google Play Store.
0
0
